@bouser and finding tables
Hi all,
are you fermilier with any scripts that can:
1.add automatically the hint :/*@variable(‘bouser’) to free-hand queries in
the repository/chosen file folder ?
2.serch in the repository user favorites folders rep flies by specific table/s ?
Yoav
yohab (BOB member since 2003-12-24)
As far as I know, the SQL property of the DataProvider object is read-only for freehand SQL data providers. So you can’t modify a query of a free-hand SQL report.
