Could anybody please suggest books or websites through which I can learn VBA/macro related to Business Object.
taps
taps (BOB member since 2017-04-27)
taps
I don’t know if it is a good idea as it concerns the old Deski module which will now remains eternally in the curent XI 3.1 SP7 release and the designer which will no longer change in the futur.
If you still want to learn VBA/SDK macro for BO, you have first to learn VBA which is not very different as the one you can use in Excel macro for example. You can also download from the SDK section of BOB plenty of codes which can help you to understand it and to design the ones you need
Also, you can maybe find in Internet some PDF regarding SDK (BOSDK50en.pdf and BOSDKObjectModel50en.pdf) but the are copyrighted
bernard timbal (BOB member since 2003-05-26)
Thanks Bernard for the information,
I will certainly try to get the PDF and VBA examples.
taps
