Does anyone know if it is possible to do a bulk load into BOMM from a spreadsheet? This would be instead of going into each Custom Attribute and entering the data.
Any info appreciated! Thanks.
Rob in VT (BOB member since 2010-02-01)
you want to import Metapedia terms to MM ? if yes, then you can import metapedia terms from excel along with custom attribute, for this you will first have to define all your custom attributes in MM, and apply them to Metapedia terms and Categories
