HI,
I am not able to view data on the views which are created on sql server tables,below is the error. Could some one help me what needs to be done to resolve this.
Data Services execution failed for TEST_. Error :
(14.2) 10-27-14 05:22:35 (E) (9668:10264) RES-020106: |SESSION JOB_VView_2122_d8e33adc_6a04_4488_94f6_599398693a82|DATAFLOW GUID::‘dc75dce5-f7cb-48c2-968d-2a01c8fa9cca’ EMBEDDED_DATAFLOW EDF_VIEW2122 OUTPUT(EDF_VIEW2122)|STATEMENT <GUID::‘dc75dce5-f7cb-48c2-968d-2a01c8fa9cca::ae771527-ae83-4863-878e-7520937c4349’ READ TABLE ICCDS_63.dbo.TBL_STG_ OUTPUT(IS_VIEW_RDR_1532_1)> Table <TBL_STG_****> for owner was not found in the repository for datastore <ICCDS_63>. Import this table from the external source. If the name is case-sensitive in the database (and not all uppercase), enter the name as it appears in the database and use double-quotation marks around the name to preserve the case. (COR-10690)
Pavani
pavani_yerra (BOB member since 2010-04-28)
