'boImg:\\' remote folder
:lol:
How to create a remote folder ‘boImg:\’ ?
Can i assign to any other BOIMG a local folder or network?
At the moment i do this:
  1. stop the “WebIntelligence Report Server” and click “Properties”
  2. The string Command must add “-images C: \ img_folder” restart
    All images contained in the folder are reportable by WebIntelligence with boimg: //
How can i assign a remote folder?
help me!!! :crazy_face:
n.poli (BOB member since 2008-05-12)
What do you mean by remote folder?
wahey :netherlands: (BOB member since 2007-05-31)
for example:
\remoreserver\img = boimg
it’s all clear…
bye
That’s what I thought. So, it’s working, right? You might want to consider using another user than the LocalSystem if you encounter rights issues.
