Can’t start the ADaptiveProcessingServer within manage server window of SIA. I have restarted the SIA, but it continues to show stopped state and disabled for 2 servers. I also have the same exact issue with the Multi Dimensional Analysis Services Server.
I was originally looking into a publication issue that i am having with what I’m guessing to be a classpath issue? That is when I noticed the disabled state on the 2 services within SIA. The following is the failed error message when running publications for a report:
Server Used: hostname.PublicationJobServer
Folder Path: Report Scheduler/
Remote Instance: No
Error Message: Unexpected exception caught. Reason: [java.lang.NoClassDefFoundError: com/crystaldecisions/sdk/occamgr/internal/EnsureActiveSession].
Log File: View Log File
Here is what the logging folder shows for one of the services not starting:
<log4j:event logger=“org.apache.geronimo.gbean.runtime.GBeanInstanceState” timestamp=“1251816497932” level=“ERROR” thread=“main”>
log4j:message</log4j:message>
log4j:throwable<![CDATA[java.lang.NoClassDefFoundError: com/crystaldecisions/sdk/occamgr/internal/EnsureActiveSession
at com.businessobjects.framework.servers.platform.modules.serversession.ServerSessionProvider.doStart(ServerSessionProvider.java:118)
at org.apache.geronimo.gbean.runtime.GBeanInstance.createInstance(GBeanInstance.java:977)
at org.apache.geronimo.gbean.runtime.GBeanInstanceState.attemptFullStart(GBeanInstanceState.java:267)
at org.apache.geronimo.gbean.runtime.GBeanInstanceState.start(GBeanInstanceState.java:102)
at org.apache.geronimo.gbean.runtime.GBeanInstanceState.startRecursive(GBeanInstanceState.java:124)
at org.apache.geronimo.gbean.runtime.GBeanInstance.startRecursive(GBeanInstance.java:527)
at com.businessobjects.framework.servers.common.fast.FastKernel.startRecursiveGBean(FastKernel.java:357)
at org.apache.geronimo.kernel.config.ConfigurationUtil.startConfigurationGBeans(ConfigurationUtil.java:374)
at org.apache.geronimo.kernel.config.KernelConfigurationManager.start(KernelConfigurationManager.java:187)
at org.apache.geronimo.kernel.config.SimpleConfigurationManager.startConfiguration(SimpleConfigurationManager.java:527)
at org.apache.geronimo.kernel.config.SimpleConfigurationManager.startConfiguration(SimpleConfigurationManager.java:508)
at com.businessobjects.framework.servers.platform.bootstrap.Boot.buildConfiguration(Boot.java:266)
at com.businessobjects.framework.servers.platform.bootstrap.Boot.doStart(Boot.java:95)
at org.apache.geronimo.gbean.runtime.GBeanInstance.start(GBeanInstance.java:513)
at org.apache.geronimo.gbean.runtime.GBeanDependency.attemptFullStart(GBeanDependency.java:111)
at org.apache.geronimo.gbean.runtime.GBeanDependency.addTarget(GBeanDependency.java:146)
at org.apache.geronimo.gbean.runtime.GBeanDependency$1.running(GBeanDependency.java:120)
at com.businessobjects.framework.servers.common.fast.FastLifecycleMonitor.fireRunningEvent(FastLifecycleMonitor.java:178)
at com.businessobjects.framework.servers.common.fast.FastLifecycleMonitor.access$200(FastLifecycleMonitor.java:45)
at com.businessobjects.framework.servers.common.fast.FastLifecycleMonitor$RawLifecycleBroadcaster.fireRunningEvent(FastLifecycleMonitor.java:291)
steiners (BOB member since 2008-10-09)
