BOE SDK and .NET
Hello,
I am try to convert a simple program from ASP to use ASPX. But I am having a lot difficulties.
In ASP, I can use
Works great with Windows AD.
In ASPX, I use
Always fail, and default to “secEnterprise” authentication? Why is it?
rs
rs90144 (BOB member since 2006-04-18)
Did you get this to work. Stuck on pretty much the same issue.
Anvy
Anverion (BOB member since 2007-03-15)
Would also like to know how you got around this issue?
Prateek
prateekjain :australia: (BOB member since 2009-10-08)
Did u find the solution for this?
Prateek
You still have to have the user ID and password for WinAD authentication. If you want to do SSO, you’ll need to look at using Trusted Authentication.
-Dell
