Hi all,
I need some advise.
I have a BODS4 SP2 patch level 3 connected to SAP SRM 7.0. I am trying to access the extractors, however those are not shown and I do not have a clue on what is the cause… I can only see ‘NODESNOTCONNECTED’ and no extractor hierarchy at all and nothing under all extractors.
The SRM 7.0 system has PI_BASIS 702 10, which is higher than the minimum patch level (702 07) as listed in: Note 1521883 - Downport ‘ODP data replication API’. There are no follow-up SAP Notes on not displaying extractors.
When I check table ROOSATTR there are entries, all with EXPOSE_EXTERNAL set to ‘X’.
When I check the functions used by BODS and the program to release extractors then those are both present. I had some doubts with SRM supporting this, but since the program and the functions are present I assume that it is possible…
See functions:
http://wiki.sdn.sap.com/wiki/display/EIM/Debugging+DataServices+issues+with+Extractors+(SAP+internal+only)
See releasing:
http://wiki.sdn.sap.com/wiki/display/EIM/Releasing+Extractors+for+use+by+the+ODP+API
When I manually import an extractor that is listed in the table ROOSATTR then I get the following message:
‘Cannot import the extractor <name=0POC_BUSINESS_ACTIVITY>. Internal error <Extractor: RODPS_REPL_SOURCES_GET_LIST failed> occurred. (BODI-1116153)’.
Or:
‘Cannot import the extractor <name=0POC_BA_TXT>. Internal error <Extractor: RODPS_REPL_SOURCES_GET_LIST failed> occurred. (BODI-1116153)’.
I have found a reference to this error, but that was because of a missing Note and not-released extractors. I have entries in ROOSATTR, so that is not the case here.
Has someone a clue what is going on here? Maybe some auhorization on the SAP BODS user? What should I check?
Edit:
I have found ‘Note 1585204 - ETL interface: Release of DataSources’. The note describes that table entries in ROOSATTR are ignored. The correction delivered in support package does not list my PI_BASIS 702 10, only 09, 11, 12… Could this be the cause?
Johannes Vink (BOB member since 2012-03-20)
