Hello Gurus, i need your help, i’m currently trying to send records to BW from a DB2 database using BODS, it was all tested in DEV and was working fine, then exported to QAS with the BW target changed to QAS. and there i’m receiving empty records in the PSA, when i execute the info package the traffic light is green and in the DS console the job log shows no error,
I’ve been searching and all post i found seem to address to the code page in the BW data store, i’ve tried changing it to UTF-8 without luck, in DEV was working fine using iso8859-1, i’ve also done a new data flow sending the info to another database to confirm that DS is extracting the data correctly and it does. Please help me find why i’m getting empty records in BW
any kind of help is appreciated, Thanks in advance
Edgar Esquivel
EdgarEsquivel (BOB member since 2011-12-06)
