system
October 19, 2012, 7:31am
1
Hi ,
We have installed BODS (Bo 4.0). we have created s some jobs on that & now I am trying to execute the job but not able to execute the job.
problem that we are facing is when I try to schedule the jobs using BODS scheduler the schedule is not getting activated…
:hb :hb :hb
Kindly Help
Vijay:
VIJAY–DP (BOB member since 2012-09-03)
system
October 19, 2012, 8:09am
2
Not able to execute a job or to schedule a job?
Regarding scheduling there were some recent topics…:
We’re using BODI 11.5, running SQL Server 2000 for the repository and source/target databases. I’m having problems deactivating an existing job in Web Administrator. When trying to select a job and activate it from the batch job schedules page, it returns the error message BODI-3016233: Unable to connect to host machine 'servername '. Error: servername. When selecting a job to view/edit its details and trying to set the “active” indicator field, it returns a “connection reset” error message.
An…
We just migrated DS 3.2 to a new data center. In the new environment (Windows 2008 on VMWare, SQL Server 2005 on one box, DS 3.2 FP5 on another) we created empty repositories and imported ATL.
When we try to create an active schedule or activate a schedule from the management console from a client machine, we get a message “Connection Reset” and it does not activate. Each time we try to activate, a log entry is made with the following error: "IsScheduleValid:fails : ERROR while getting schedu…
I have recently upgraded our BODS environment from 3.1 to 4.0. I installed 4.0 on a new server and upgraded the repo.
The problem I am facing now is two-fold. I managed to remove old job servers from the server manager by editing the dsconfig.txt, but I still see references to these jobs in both Designer as well as Managment Console (when trying to schedule a new job). I also see adapters associated with no longer existing job servers.
Another thing is that I cannot schedule jobs. I can, but…
Johannes Vink (BOB member since 2012-03-20)
