BODS job sometimes get fail due to COn-120307 error. When it is rerun it gets successful. Kindly help to remove this error permanently.
Below is the error:-
(14.2) 06-13-17 06:21:57 (E) (27274:1216980768) CON-120307: |Session JB_HANA_TRAIN_TRACK ODBC call to connect database <> failed with error: <[SAP AG][LIBODBCHDB SO][HDBODBC] Communication link failure;-10709 Connection failed (RTE:[89006] System call ‘recv’ failed, rc=104:Connection reset by peer)>. Use the ODBCDriverSelector (Windows) or DSConnectionManager.sh (UNIX) utility in LINK_DIR/bin to configure the correct version of the driver. If the problem still exists after selecting the correct version of the driver, notify Customer Support.
priyankagupta (BOB member since 2017-07-05)
