BODS Job Failure
Hi Collegues, I’m new into BODS, but currently I am experiencing an issue with one job.
The thing is that the process call a webservice (expesite is the vendor), and it seems to don´t work when the process runs, but if I execute the code lines separately into SOAPui, the webservice responds.
This is the output log from BODS for the job:
.2) 05-19-16 09:52:03 (E) (7872:6936) RUN-248005: |Data flow DF_Store_To_Expesite_GetSessionToken_Prd|Transform Query_FunctionCall-Function2
There is no response for the web service . Ensure that the network, web server, and service are running
properly. Also ensure that the service client call time out is set properly.
(14.2) 05-19-16 09:52:03 (E) (10516:9652) RUN-050316: |Session JB_Store_To_Expesite_Prd_2
Unable to get Session Token
(14.2) 05-19-16 09:52:03 (E) (10516:9652) RUN-050304: |Session JB_Store_To_Expesite_Prd_2
Function call <raise_exception ( Unable to get Session Token ) > failed, due to error <50316>: .
I don´t know what to do, Would you help me please??
panchs007 (BOB member since 2016-05-19)
