Hi Experts,
BODS Data Flow Received bad System Message and died abnormally while calling SAP ECC BAPI Functional module. (BAPI for Mass Material Maintenance eg BAPI_MATERIAL_SAVEREPLICA)
Please note that, This error occurring every time only when I map User defined segment in BAPI (eg MARA and MARC User defined Z Segment), if I remove those mappings then Data Flow completing successfully.
Beauty of this error is sometime Dataflow is completing successfully even with ZSEGMENT Mapping, so here I am completely confused why some time working fine and other time it is failing.
Here I have Attached Error Message and ZSegment Mapping for your reference.
Could you please provide your suggestion for solution or how to find the root cause for this issue.[/b]
BODS version is : 4.2 SP5
Ymuthusa (BOB member since 2016-02-11)
