BODS: Cluster Tables (CDPOS, KONV)
We are facing lot of problems when extracting SAP Cluster tables (CDPOS, KONV) into SQL Server.
Initially - The tables are joined directly in BODS and extracted - No Luck in extraction. The Job took around 9 hours and failed.
Then based on some KB articles - We understood to read these huge tables via ABAP data flow which we created but still the results are same with performance issue. :hb:
So, Now we opened a HIGH priority ticket with SAP for suggestion (still waiting for their response)
Does anyone already worked on similar requirements of extraction using cluster tables ?
Hari
bh.hari.krishna (BOB member since 2015-01-20)
:hb: Looks like there is no solution in BODS :hb:
