Hi all,
While installing SAP BODS 4.2 SP7 & IPS 4.2 , we found an error " A FATAL ERROR WHICH HAS CAUSED INSTALLER TO QUIT. PLEASE GATHER ANY %TEMP AND INSTALLER LOGS TO PRESENT TO YOUR SUPPORT.
For this issue the given solution is we need to disable the Disable UAC ( User Access Control ) is to modifying registry on the machine.
Steps to follow:::
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System. In the details pane (Right Pane), locate the EnableUA key (REG_DWORD type). Double click to Modify. In the Value data box, type 0 (zero), and then click OK.
MY QUESTION:::::
My Administrator Server (Windows server 2012 R2) is already installed with SAP BI BO 4.2,SAS and other software if we Enable the UAC it will impact the other installed one.
Ramkumar R
ramkumar.r (BOB member since 2006-02-22)
