BODI-1112275 Error. Please help.
Hi Experts,
I am new to the forum and seek your advice on resolving one of the issues I am facing.
I am not able to checkin - check out or even take latest with dependents or with filtering from my central repo to local.
I am getting below error.
[b]BODI-1112275 Internal error in ‘central repository’. Objects in central and local repositoies don’t match.
The following objects in dependency list constructed from the repository cannot be found in the corresponding dependency list in the cache.
Imported function- …“R/3”.DS_SAP[/b]
There are 2 BAPI functions in my local and central and they are causing issue. However error is not naming them but coming as Blank.
Functions are - BAPI_ACC_GL_POSTING_POST
BAPI_TRANSACTION_COMMIT
Is it that these function have some reserve words? My datastore is case insensitive.
When I compare my local datastore DS_SAP to central repo datastore, it shows both of them to be deleted from central repo, but I can see them in central repo. Sometimes I need to refresh my central to see them.
I created another central repo and put my code there, but the problem still persists.
I am not able to take latest from central in an empty local repo as well.
Attached is the error snapshot. Please help.
atomer (BOB member since 2015-07-24)
No response. :cry:
I don’t know what the problem is. I would start by looking at the AL_LANG table in both the central and local repositories to see if that looks correct. Otherwise, contact SAP technical support and open a case.
AL_LANG and AL_FUNCINFO looks correct. I have also raised an OSS for SAP tech support. Lets see.
Meanwhile I am re-designing the impacted dataflows in a new local and will use a fresh central for that. Lets see if issue still persists.
Thanks!!
I am getting the same error. How did you fix the isue
gupta.prakhar.93 (BOB member since 2017-10-17)
