BO XI - WEBI Error
I have installed BO XI on windows 2003 server. when i access infoview and click new web intelligence document, it throws below error.
An error has occurred: Could not initialize Report Engine server.
appreciate if you could help me in resolving this.
Ravi
rvidela (BOB member since 2005-05-28)
Log into the CMC and make sure that the Report Engine Server is running.
i could not see any server named “Report Engine Server”…But all servers are in Running state.
Tavi
I just checked, and it’s called the Web Intelligence Report Server. That’s the one you need to create a Web Intelligence document.
That is already in Running mode. as i told, all the servers in CMC are in Running mode. Appreciate your helpin resolving this.
Ravi
I am also receiving this error when trying to create a webi report through xi r2. I checked the web intelligence report server and it is running. I was wondering if you found a solution.
An error has occurred: Could not initialize Report Engine server. (Error: RWI 00226)
twill :confused:
twill (BOB member since 2005-09-14)
Is it running and enabled?
I disabled my development one but left the service still running and got the same error as you.
DavidL :us: (BOB member since 2005-05-06)
DavidL has a good point. A server can be running in the CMC, but disabled. Log into the Web Admin tool to see if the “Servers” are running. Also in the CMC see if the servers are disabled. You need to click one of the icons on top to see the enabled/disabled servers in the cluster.
cduey :us: (BOB member since 2002-09-05)
I am having the same error, but it is related to user rights. This occured to me when I first time wanted to create a new WEBIreport, but had no rights to use the HTML panel. When I authorized the group to use the HTML panel it worked. Altough the user has selected the Java Report Panel. :crazy_face:
Wolfgang
wprankl :de: (BOB member since 2005-04-20)
Thanks Dave,
I enables the servers and it is working now. Thanks.
Fan
bob_fan (BOB member since 2008-04-07)
Another reason for this error is that some groups do not have access to execute a WEBI report that is assigned to specific servers groups. I came across such a report where the user complained that any attempts to execute the report was causing this error. After exhausting all methods I could think of I checked the server group in the schedule page and the user had no access to the group the report was defaulted to execute under. I clicked on the First available server option and it fixed the problem
Thank You
Rik
rhodeislander (BOB member since 2006-06-17)
I had the same problem.the error was
An error has occurred: Cannot initialize Report Engine server. (Error: RWI 00226)
When i restarted the FILE REPOSITORY SERVER ( Input file repository server) in the CMC , it started to work fine.
frilto (BOB member since 2009-10-11)
Hello Experts,
I am also getting the error:
I checked my Web Intelligence Report Server is up and running in Central Configuration Manager however, it is stopped in Central Management Console > Servers.
I tried starting it but no reponse. I tried disabling and enabling… however still no reponse… :hb:
Please help…
Thanks & Regards
mariasundarrajs (BOB member since 2009-11-01)
mariasundarrajs,
Welcome to B:bob:B!
You’ve got an unresponsive service. You may need to kill it in the Task Manager, if you can figure out which service to kill. Otherwise, reboot.
There is no problem with services, however in Java admin launchpad, Central Configuration Manager > Servers the server (Web Intelligence Report Server) is in stopped state… what ever I do, either stop/start or disable/enable there is no change in the server state. It is in stopped state only with red icon.
please help.
If you still havn’t found the answer visit the following link :
This will solve your problem.
Naveen G :india: (BOB member since 2009-11-15)
