I have downloaded the BO XI 3.1.But i dont have the Key for it …
can any bopd help me with the trial key or tell me where can i find it.
Thanks in Advance
Harish
harish_gai (BOB member since 2008-11-24)
Thanks in Advance
Harish
Check the mail you had gave or it should be there in downloading window. Check it out…
BOCP (BOB member since 2007-07-02)
Thanks for your Reply.
I have a product id but its not working.
Can you help me out in any way.
Harish
It should work, make sure that you took correct one.
Unfortunately, am not using any trail version…
Wait, someone may guide or give you…
Thanks for the Response
Ragrds
Harish
I suggest you contact SAP directly…
Andreas (BOB member since 2002-06-20)
