BO XI Job Monitor?
I am new to BO (running XI) and am searching for a way to easily view and monitor scheduled, pending and running jobs on the CMS server. Using CMC, I can drill into each object to see if it is running or not, but that is tedious.
Is there a utility/tool that can show me all scheduled jobs in a consolidated view…which are pending…which are running, etc? Thanks.
Dave.
dfhoover (BOB member since 2008-10-08)
have you tried this : ?
http://www.zoom-software.com/
… and welcome to B :mrgreen: B
Thanks Bernard. I have not tried it, but it seems to be what I’m looking for. Thank you.
Dave
Check this tool in BoB’s Downloads section:
https://bobj-board.org/t/111635
Rachid
rachidb :morocco: (BOB member since 2006-07-06)
Thank you. I am getting the same “can’t find project or library” error as an earlier post, but I am also not able to access the Tools>References option…it is grayed out.
We are on BOXI. Is this tool only compatible with R2 and above possibly?
Dave
If References is greyed out it means you are still in Debug mode. Click Reset button and try again.
The tool should be compatible with BOXIR2. I have not tried with XI3.0 as we have not upgraded yet.
Rachid
Thanks Rachid, that got me through and we got it working. Is there a way to store the login credentials (system,username,password) so we do not have to enter it each time we “refresh”?
I will post the reply in BOB’s Download thread so everyone using the tool can benefit.
Thanks for suggesting this.
Rachid
