BO XI installation
When installing BO XI , could someone confirm that It will automatically install Crystal XI on my machine .
gogo (BOB member since 2005-06-03)
It wont, you have to install crystall report.
kerrynns (BOB member since 2012-02-28)
Are you sure about that as I thought from BO XI , Crystal XI was part of the install as you can export Crystal XI reports to Infoview as well as view Webi reports.
“Crystal Reports 2011” and “Crystal Reports for Enterprise 4.0” are each separate installs as they are client tools. Same holds true for example for Xcelsius/Dashboard Designer 4.0.
Great with regards to Crystal XI. Once installed on my machine, do I need to establish SQL Server DB connectivity on the BO XI server and then I will be able to export my Crystal XI reports to Infoview ?
Also what do I need to do to migrate existing reports from Crystal Decision 10 to Crystal XI
