Iam using windows 7 and I want to install BO XI 3.0 (Server) on my system.It is by default installing in " C:\ Program Files(x86)\Business Object" path.Is it correct?.
Also how can i check the installation software is 32 bit or 64 bit?
You can change the default install path by entering something different (like D:\Program Files(x86)\Business Object) if you wish.
BO XI 3.0 (and 3.1) are only available as 32 bit versions.
Blair:
We got environments SP3 or SP5 were the software get installed on D:\Program Files(x86)\Business Object) or D:\Program Files\Business Object) and we haven’t notice any difference.
I got his note from "Supported Platform"guide: Note: The 32-bit compiled binaries of SAP BusinessObjects Enterprise software is supported on 32-bit and 64-bit versions of the Windows operating system (running on either x86 or x64 CPUs made by AMD and Intel).
Be aware, only SP3 and up introduce support for 64-bits. Any version lower than that and you are in 32 bits
I have installed it on default path but i am gettting error in CMC while login
i.e
" Bad port number in CMS name fe80:0:0:0:806c:f771:cc6c:2c10:6400 nul"
i found all of the servers are disabled except central management server.I tried to restart them but could not.
I disabled the firewall and i am able to start servers and able to login in CMC but i am getting one error while trying to create connection in designer
CS:DBDriver failed to load: C:\Program Files(x86)\Business Objects\Business Objects Enterprise 12.0\win32_x86\dataAcess\connectionServer\dbd_oci.dll(The specified module could not be found.) "
Also when i logged in infoview and try to create report i could not find any universe listed .Also checked in designer no efashion or island resort marketing was present
I changed the installation path of Business Objects from “C:\Program Files(x86)\Business Objects” to “C:\SAP\Business Objects”.
Reason:
i am using oracle 10g and its installed at “C\Oracle…” but BO was installed at “C:\Program Files(x86)\Business Objects” so oracle was not able to find .dll file.
Everyone, I tried to install in c:\program Files\Business Objects instead of c:\program Files (x86)\Business Objects. How can you force to install in c:\program Files\Business Objects. Just FYI, I don’t have server running on my machine and no odbc connection on my machine. I need to connect to server and run deski report. I have xi 3.1 sp3/oracle 10g on my machine. but giving sql or connection sentence error.
