Is any one documented differnt features and advanatages and disadvantages with BOBJ and Tableau.
Could you please share here .
thanks
pavan_au143 (BOB member since 2007-07-25)
thanks
It also depends on your data source. If it is SAP BW, then SAP BI BusObjects (with Analysis MS Office, Webi, DesignStudio, etc.) is almost a no brainer.
Andreas (BOB member since 2002-06-20)
If you have nothing in house (no experience of either), then it’s a cleaner decision but these comparisons never take that into account.
Thank you soo much for your replay all,
actuall we are using BOBJ ,but my managment want me to prepare the differnces
thanks
Which version of BO are you on and what components do you use?
What data sources do you report against? E.g. Oracle, SQL Server, SAP BW
thank you for ur relay,
we are using Boxir3.1
db:sql server
products:
1.universe designer
2.Webi
thanks
You cannot compare Tableau to BOBJ in general as you have to compare like for like i.e. either Xcelsius, Lumira or Dashboard Manager.
Personally, I think Tableau is the most efficient Dashboard tool I have ever used
MikeD (BOB member since 2002-06-18)
In terms of development time, flexibility, performance and scalability, Tableau or other in-memory tools like QlikView must win WebI
The advantage of WebI I could think of is the reporting function and ad hoc query capability. As mentioned, it is hard to compare 2 products with different strength but I will say WebI is losing in the market when competing with Tableau
ohtiek (BOB member since 2006-09-03)
Hiii , Basically BOBJ is a reporting / Analysis tool which comproses several other tools within it and tableau is analytics and data visualization tool. For the comparison you can go through these links. Hope It will help you.
http://intellipaat.com/tableau-training/
https://www.youtube.com/watch?v=AyzIchw2Lik
http://www.trustradius.com/compare-products/sap-business-objects-vs-tableau
alvin daivd (BOB member since 2014-07-03)
