BO Universe designer connecting to Postgres
Hi all,
I have Boxi 3.1 SP5 server and Postgre-9.6 DB server, both are under Linux environment.
I had copied jdbc driver under /opt/app/Enterprise/bobje/enterprise120/linux_x86/dataAccess/RDBMS/connectionServer/jdbc/jdbc.sbo file.
and fill in the path,(for postgres and generic jdbc) :
/home/xxx/postgresql-8.3-606.jdbc3.jar
when I open the Universe designer from my laptop, it always failed. Kindly please help me to solve my problem.
ardi1103 (BOB member since 2017-08-14)
Any error message?
Hi Nick,
here is the error snapshot.
Universe designer is a client tool, it wont be able to work with the JDBC driver on your Linux server. Youd have to install a JDBC driver on your laptop. The JDBC on the server would only be used when you publish reports based on the Universe you create.
ohh… thanks for your information :slight_smile:
ok I had put the driver in my laptop and configure the jdbc.sbo file :
C:\jdbc\postgresql-8.3-606.jdbc3.jar define java class for JDBC driver $DATASOURCE$
but I still got an error “CS: Java Class not found in classpath : define java class for JDBC driver”. Do I need to define this parameter ? define java class for JDBC driver
how I should fill the parameter?
trying to put JDBC parameter and update the jdbc driver for jre7(I’m using jre7) like these :
C:\jdbc\postgresql-42.1.4.jre7.jar
org.postgresql.Driver
$DATASOURCE$
but still got following error :
CS: Java Exception : java.lang.UnsupportedClassVersionError: Bad version number in .class file
any idea?
How is this related to SAP Data Services?
ErikR :new_zealand: (BOB member since 2007-01-10)
Apologize if I put my question in a wrong topic.
do I need to close this and open a new subject in the “DI: Installation, Administration, and Connectivities” ?
thanks
I have moved this to the correct forum.
Bob Junior :uk: (BOB member since 2005-04-23)
Thanks Bob
