Hello,
I really need your help Please. I am a beginner in Business object and I don’t know how to realise my request.
So, I have an attribut that can has many value depanding of another one, so me I need to separate them to use them in others request.
this is the link to an image illustrating what I try to explain, Numéro matériel id the ID
The attribute “Classe 30 sous classe 10” can have two value. And I don’t know how to separate them. I tried to write this formula but it doesn’t work :
=<Montant de l’opération> WHERE ( <Numéro d’Opération Financière>=Max(<Numéro d’Opération Financière>))
As refered in the picture that I added, I want to have this presentation :
18548, 75 , 28 886
and not 18548, 75
18548, 28 886
Beause I have to add more informations, and ith this presentation, I will have duplicates
Create a Boolean flag for each value you want to check.
Then create a max() function for each flag in the =<Montant de l’opération> operation and insert in the report in place of the original object. That should create a single row per =<Montant de l’opération> (depending on any subsequent additions).
