BO reports - number of hits and scheduled infomation
is it possible to get the number of hits in a report (Repository). and scheduled informtion ( status , error information)
Please give me your points.
Tx
Nags :india: (BOB member since 2007-02-07)
The second part should be possible by instance manager from admin launchpad
What does number of hits means?
Hi Haider
Number of hits means how many times the reports opened / refreshed . and scheduled information - can we take it via SDK .
Tx
Both should be possible using SDK, search for it on the SAP BOBJ site and also on BOB
But why are you averse to using instance mananger
Number of hits can only be done if you have auditing on. Activity universe should give you that info.
Scheduling info you can get using SDK. Check XIR2 scheduling instances viewer tool on BOB’s Download:
Hope this helps,
Rachid
rachidb :morocco: (BOB member since 2006-07-06)
