BO POPUPS and List of Values
Hello,
I have migrated reports from one database to another (DatabaseB).
However I am having problems with POPUPS with the new database.
I have an Object in the universe with this select:
DatabaseB.POPUP(‘Boolean’,DatabaseB.BOUSERINFORMATION.CANCHANGEPRICESPN)
When I try to Parse this I am told that - DatabaseB.POPUP is an invalid identifier.
ALso when I look at the Object properties although it has a list name (where is this list held?) when I try to Display I have an SQL sentence error.
Any Suggestions??
many thanks in advance
MIDZ (BOB member since 2010-04-07)
What RDBMS are you using?
Is POPUPS a function that was created in one database but that either:
  • does not exist in the new database or
  • the connection account has not been granted execute on?
The RDBMS is Oracle.
The POPUP function was created in the original database which I migrated the Universe from. The Object is still pointing at the Original database but when I try to change it I have an error message.
Surely the POPUP function (if it is a function?) would have been migrated too with the import of the universe?
Many Thanks
The POPUP is not a function since it does not have @ in front of it.
Database functions (or tables, views, stored procedures, database indices, etc.) are NEVER migrated with a universe. That is something one must take care of separately on the database side.
That simply means that it is not a BusinessObjects function, which we know it isn’t!
It is a database function that needs sorting out as we have said.
Thank you for that!
Will try to change the Database function.
