We have clustered env(01& 02 servers), Networking team provided us with ‘businessobjects:8080/BOE/BI’ url that will do load balancing.
Question: 1. How to remove ‘8080/BOE/BI’ from ‘businessobjects:8080/BOE/BI’ URL. As business requirement is to have business friendly BI URL name to only ‘businessobjects’
When we click on ‘businessobjects:8080/BOE/BI’, landing on ‘BILaunchpad’ page. System Name: is showing as ‘01:6400’. Is there any way to rename ‘01’ as ‘businessobjects’?.
How to get same system name (eg: businessobjects) when click on ‘businessobjects:8080/BOE/BI’ as this URL is pointing to ‘01’ and ‘02’ servers.
You can get rid of the 8080 portion by changing the port number in the server.xml file if you use Tomcat as your web server. If you use some other software for your web server, you will have to find where this is designated. As far as I know, you cannot remove the BOE/BI part of the url after they navigate to it.
This is actually determined by which server your url happens to route you to. As far as I know there is no way to change this. You could configure your system for single sign-on and then they would never see the login screen to see the system name.
You won’t get the same system name because your load balancer is selecting the server it connects to. Like number 2 above, you can use single sign-on and they won’t see the system name at all.
To allow users to use the “businessobjects” in the url without “\BOE\BI”, you’ll need to add a file called “index.html” to the :\Program Files (x86)\SAP BusinessObjects\Tomcat\webapps\ROOT folder on both web servers. In that file, put the following:
For configuring the cluster, you’ll need to create a couple of custom .properties files in the :\Program Files (x86)\SAP BusinessObjects\Tomcat\webapps\BOE\WEB-INF\config\custom folder on both web servers. (NOTE: these file names are case sensitive!)
BILaunchpad.properties, CmcApp.properties, CrystalReports.properties, and OpenDocument.properties will all have this line:
Replace “” with the name of the cluster and “<server…>” with the name of each server.
Restart tomcat after making all of these changes.
You should now be able to go to http://businessobjects and get to the login page and then use the @ instead of the server name to log in.
