I need to have full client installed on my pc. I do have questions in regards to the install. I am running SQL Server 2000. Can a BO application be installed on a server as a stand-alone without having to install a client connection, so I would not have to install a server and client
setup?
I’m not quite sure what you mean. Are you saying that you don’t want the full-client products installed on your desktop – you only want the server products installed on the server?
The server product allows WebI/ZABO queries to be run. However, you’d typically want the full-client products installed on at least one PC, so that the Supervisor/Designer could build and export universes, and manage the users via Supervisor.
