I am trying to install BO Edge trial version 3.1. But it gives me error: The product keycode you entered is not valid. STW00140
after i enter the product key and hit next.
Product key is the one I obtained from SAP after registering for the trial version. I am pretty sure that it is correct.
I had Xcelsius trial and BO Client installed on this computer earlier. I did uninstall both of them and also deleted all registry entries.
I also tried following this thread but that too didnt help me:
I tried registering again and it gave the same keycode, I was wondering if I anyone else has received the same keycode and tried the install with success.
I even tried installing on a clean Win2K3 machine, still got the same error.
So I am beginning to doubt if its the keycode or some other issue.
This is the keycode I have:
XXXXX-XXXXXXX-XXXXXXX-G5TJ
Hi Folks,
I had the same problem and it turned out, it is an issue with the current year.
On one machine I turned back the date to the last year, and suprise, the key is valid.
Rg. Schweizer
