BO Designer SDK
Hi:
I am very new to BO so please bear with me…
What is the BO Designer SDK? What can it be used for?
So far I understand it as a tool that reads metadata from a universe and outputs it for the user (or vice versa… feed metadata into the universe). Any help?
knight03 (BOB member since 2007-11-30)
The Designer SDK allows VBA or C to access the data structure of universes.
I have used it in the past to create a VBA macro in Word which created a document which listed all the classes and objects (and help text) to provide documentation. It also listed all the derived tables and contexts
I have also used it to check the differences between 2 universes.
SteveMS :uk: (BOB member since 2003-04-03)
We have set of downloadable macors to help with Designer
For Universe Document Generation.
For Creating Classess and Objects Automatically.
Mass update or Object Description.
Apart from these, we have some other downloadables…
Siva.M
looksmee :uk: (BOB member since 2006-02-08)
