Dear colleagues,
I’m trying to extract data with DataServices 4.0 (SP2) from BW on HANA through OpenHub Destination and we are facing connection problems.
There’s also a traditional BW and we connected using an RFC and the connection test on SM59 worked fine.
However, we created another RFC for BW-HANA and the connection test on SM59 failed with the following error:
Logon - Connection Error
Error when opening and RFC Connection (CPIC-CALL: ‘ThSAPOCMINIT’ : cmRc=2 thRc=67
ERROR: program DIHASOURCE not registered
DETAIL: TP DIHASOURCE not registered
COMPONENT: SAP-Gateway
COUNTER: 39789482
MODULE: gwr3cpic.c
LINE: 1803
RETURN CODE: 679
SUBRC: 0
RELEASE: 720
TIME
VERSION: 2
And the log error files on DS says: “Timeout during allocate of registered program”
We created the RFC at de Administration Console and the connection is “Started” and we can import tables and OpenHub to the local repository in DTS when creating the DataStore.
Did anyone have the same problems?
Is there any known connectivity problem or restriction between BW-HANA and DS 4?
Thank to all of you!
inver5 (BOB member since 2012-05-23)
