BO compatibility matrix
Anyone has any idea about BO compatibility matrix or similar document?
I’m busing BOXI SP1, interested to find out what’s the latest JVM version we can use on the server.
Guoming (BOB member since 2007-10-30)
Yes, look for the Product Availablility Report(PAR) on the Business Objects / SAP website…
I can’t seem to find this document. Do you have a link perhaps?
Chaos (BOB member since 2009-07-09)
It is very difficult to get PAR file online, probably because of the fact that they are dynamic by nature and keeps getting altered with release of fix packs etc.
You would be better served to check with SAP. Open a ticket and they should be able to give you the PAR file.
BO_TN (BOB member since 2008-07-30)
