BO Certification - BOCP - BOE
I have appeared for the SABE 201 certification on 8th Nov, 2008. I wanted to know whether there is a specific time-frame in which we need to appear for the next two papers (namely, SABE 301 and SABE 401) or else the appeared paper will be treated as VOID.
Roger
rpdsouza_28 (BOB member since 2008-11-10)
There is a sticky topic regarding certification questions. Is the answer to your question not there?
dessa :madagascar: (BOB member since 2004-01-29)
Thanks dessa
I found the answer to my question in the sticky topic, but i had to scroll through many pages to get the same. Isnt there an easier method of finding the topics of your interest.
:slight_smile:
Roger
You needs to get into BusinessObjects Certification Exams. No easy way other than this. :smiley:
Siva.M
looksmee :uk: (BOB member since 2006-02-08)
As has been pointed out, this topic has been discussed extensively in another topic. Therefore, this topic is now locked.
