BusinessObjects Board
BO Auditor for 5.1.4
I use BO 5.1.4. I need to get the list of users and their statuses (enabled/disabled).
Hence, I took 1-Enabled and other statuses by default as disabled. But, when I verified these details in Supervisor I found that many users exist with statuses other than 1 who are enabled or disabled.
So, I am unable to fetch the right data.
Could you please tell me if there is a way to get these details. If not, could this be a problem as BO 5.1.4 has no auditor?
Early replies would be helpful!
Srujana
srujana_j (BOB member since 2003-12-09)
I think you don’t need auditor. just query the bo repository database (obj_m_actors) and you should obtain the information you want. I suggest you to have a look to bo repository database description which should be in BOB Download section
regards
bernard
Check out this link
KhoushikTTT :us: (BOB member since 2005-02-24)
