BO and SAP BW Integration
Hi all,
A quick question: The SAP Integration guide talks about Add-ons to connect to SAP BW with BO. Are these connectivity Addons (for data access) part of SAP Integration Kit or they are supposed to be downloaded other than SAP Integration Kit.
I am planning to work on BOXI 3.0 with SAP BW for a client. Any other thing which would be worth noting because I don’t come from a BW environment and have to take this task to integrate it with BO.
P.S. I have been through many posts but did not find answer to this particular question.
aneelf (BOB member since 2006-05-15)
if using CR onto BW you have to import a couple of transports into BW. these transports are part of the installation cd. However you also need 2 files. these need to be downloaded from sap site.
you also need the latest SAPgui 7.x
E10 :netherlands: (BOB member since 2003-04-16)
