BusinessObjects Board
BO Admin - Query Builder
Does anyone know how i can query list of reports by universe ?
DesiGuju (BOB member since 2007-04-23)
You will need to run two different queries in query builder.
  1. select from ci_appobjects where si_name = , there will be a field named si_webis that contains the id’s of all the reports that use the universe. Add these id’s to the second query.
  2. select si_name from ci_infoobjects where si_id in <list of id’s from qry 1>
You can certainly do this with the SDK
jwhite9 :us: (BOB member since 2006-07-28)
jwhite9,
Thanks for the reply. Query work fine. Is there a way to export query result to excel or csv file ?
There is no way to do this from within query builder. You would have to write some custom code to get the output in another format.
One more questions. Is it possible to display data by column and row ?
When we run the query in query builder results are listed as
Column Name : Value
I would like to display the resutls as
Column Name
value
value
value
The formatting of the results is done in the JSP/ASP pages and if you are a GURU in coding play with the application pages.
Sheshachala5 :india: (BOB member since 2004-01-09)
The Query Builder is designed for quick retrieval of isolated or small amount of information. It is not meant to be used for reporting purpose. This is where the SDK comes in.
Some people have succeeded in copy-n-paste the query result into Excel for further manipulation. But it is a tedious task and it may or may not work every time.
In Query Builder I am trying to club these two queries into a single query but not able to do so, has any one done that ?
Thanks in Advance,
Vinod
vinodk (BOB member since 2006-12-01)
have a look at the excel doc here How to find the list of reports developed on a universe? it may help.
Sushir Patel :uk: (BOB member since 2006-04-19)
This query returns Webi reports that are based on a particular universe:-
SELECT SI_ID, SI_NAME, SI_WEBI , SI_OWNER
FROM CI_INFOOBJECTS, CI_SYSTEMOBJECTS, CI_APPOBJECTS
Where PARENTS("SI_NAME='Webi-Universe'","SI_NAME ='Your Universe Name'")
Check this post for a sample of how you can use the SDK to retrieve data from the InfoStore:
https://bobj-board.org/t/115414
darcstorm :philippines: (BOB member since 2008-07-22)
Mak,
Thanks the query which you gave is working for me, but I am not able to find the folder name of the report, I tried with SI_PATH and SI_FOLDER_NAME1 but no luck. Can you help me in this ?
And for the query which you gave there are no joins between the tables, and how is it working can ou explain me the query ?
And last question…I heard that there is a universe on repository tables, where can I get that ?
Thanks in advance.
Vinod
Mak thanks, the query is working…but I am not able to find the folder name of the report, I tried with SI_PATH and SI_FOLDER_NAME1 but no luck. Can you help me in this ?
Thanks in advance.
Vinod
I’m afraid not, I don’t know the answer to this.
Someone else gave it to me and it works, thats all I know… :slight_smile: .
Its called the Activity universe and should be installed by default.
Cannot say if that is possible in query builder,but you can get it the other way round
To list reports in a particular folder by running 2 queries
Find the folder name
SELECT SI_NAME, SI_DESCRIPTION, SI_PARENTID FROM CI_INFOOBJECTS WHERE SI_KIND IN ('FullClient', 'Webi')
pass the folder name or parentID from above query
SELECT SI_NAME, SI_DESCRIPTION FROM CI_INFOOBJECTS WHERE SI_KIND IN ('FullClient', 'Webi') AND SI_PARENTID=123
I am looking for a single query where I get the list of report names and the folder name for a given universe. Not sure if it is possible.
Vinod
But you had asked about the documents folder and not universe folder?
I guess you cannot get the universe folder name along with list of reports in one query using query builder
Thanks for your reply…I don’t want the universe folder name…I want the report name and the report folder name for a given universe using a single query.
Vinod
To get list of reports for a univese you will have to run one query on CI_APPOBJECTS.
Use this list of reports to run another query on CI_INFOOBJECTS to get report & folder names
But you may not be able to join them to have one single SQL
Could someone please let me know, how to find out list of ALL reports (not only webi) based on a particular universe.
Amogh
PAmogh (BOB member since 2008-08-30)
