I know it is very old now but need need to get your inputs. ![]()
Is there any way from within the Business Objects server to specify or control which JRE version the client is to run? -
Can the Business Objects report designer be run from within Java directly on the client instead of initiated via browser to Business Objects Reports?
Client had updated their workstation client to java 8 and they cant run the business objects plugin from the browser.
There are some workarounds if they go back to java 7.5.
its_ranjan (BOB member since 2011-02-16)
