BO 5.1.5 compatible with Oracle 9i ?
Hello,
can anybody confirm if bo 5.1.5 is compatible with Oracle 9i ?
Thanks in advance !
mb_prof (BOB member since 2005-11-25)
We have BO 5.1.3 running with oracle 9i and it is running perfectly fine.
edyl
edyl (BOB member since 2005-10-03)
edyl, do you run data providers with oracle or also the repository ?
Best regards,
Martin
All of our data bases here are oracle 9i including the one that hosts our repository. At first we had the same doubt but since we moved about 7-8 months ago we have not run into database issues as of yet. However there was no 9i connection definition listed in the connection wizard, i used 8i from the choice and it is doing fine.
edyl
