BO 5.0 Repository
Can we use 5.0 repository to store 4.0 documents?
Harpreet
Yes this works fine.
You should be using 5.01 or 5.02 for your deployment of 5.x. The initial (5.0) release has many bugs in it that will drive you crazy.
Sincerely,
Tom Nather
Data Warehouse Group
Penske Logistics
email:tom.nather@penske.com
Phone: 216-765-5787
Fax: 216-765-5666
Yes*… Actually, it doesn’t look like the document domains get changed during the upgrade.
Good luck,
Brent
*Yes, right? - if I’m wrong, please jump in on this…
Harpreet
Tell me about it !!! Can you tell me how long version 5.02 has been available for?
Mark Davies
Sincerely,
Tom Nather
Penske Logistics
Phone: 216-765-5787
Fax: 216-765-5666
Harpreet
