I am using BO 4.1 on the C drive. Now I wish to install the version 4.1.3 on the D drive. I tried, but, it is referring old version and overwrites. Is it possible to keep both the versions on the same PC. Please give me any suggestions. Thanks.
Ravi,
it’s not possible unless you do some serious tricks with the registry. That’s where BO stores all the info some other apps put in a INI file. (and that’s where the info should be btw).
