I have used two blocks in my WEBIXIR2 report Block1, Block2. The problem is Bolck1 has the larger no of data. So what happens Block2 overlap with Block1. Could any one please assit me to resolve the issue.
Use the similar logic to implement the same in Web-I as Damocles suggested. Go through this thread where the solution for this problem is suggested for Desk-I. This would help you gain how to position with respect to another block.
Go to properties tab —> page layout —> Postion. Click on that and apply relative position, you can apply left as well as top edge positions. Make top edge position as 0 from the bottom edge of block 1. This gives you the proper alignment for your blocks even though the data changes.
