BusinessObjects Board
Blank Square in Dashboard SWF
I have a new dashboard, when I execute the Swf I see a small blank square near the cursor.
I use the SWF component in the dashboard, because these SWF are include into the principal dashboard.
Image where the error is attached .
The version of the dashboard is 4.1 SP 5.
I have many test to solution this problem, but not work.
I tested with Dashboard 4.1 SP 4 and Dashboard 4.0
I reinstalled the flash player, exported to PDF and Html.
Please, Any ideas to solution this problem? :hb: :hb:
tobias99 (BOB member since 2015-02-13)
Welcome to B:bob:B!
[Moderator Note: Moved from General Discussion to Xcelsius - Crystal Dashboard Design]
Is it always there, or only over certain areas? Given the size and location, it looks like a tooltip with no information in it. Why exactly it’s showing up, though, is a mystery.
If it’s always there, try it with different browsers and on different machines. Maybe your browser/Flash settings are creating an odd behavior just with the SWF file in general.
If it’s only over certain areas, try looking at the tooltip settings of those components, or of the canvas itself. You may have a tooltip set to read the contents of a cell that is blank.
It´s for all objects on the dashboard.
I tried in different environments (DEV, QA and local machines) and different browsers (IE, Mozilla and Chrome)
I am generated the SWF in other machine and I have the Same error.
Then that sounds like a peculiar setting with Flash rather than with Dashboards. Can you go to the Adobe Flash site and see if you get the same behavior with the test content on their site?
