Bizarre Problem
Hi all
I’m having a very weird problem, when I try to insert a new table in my universe, BO shows me the table list, but when I try to check the fields inside each table, It doensn’t show me anything. I can’t insert the tables either, but if I try it, it shows me the values. What can be wrong?
I’m working with BO 4.3.1, Informix Dynamic Server 7.3. TIA
Brgds
Omar
I’ve seen this before after a new version of a database was installed and the middleware needed to be upgraded. If you haven’t had any changes of this nature then I would check to make sure your connection is ok, then make sure the user id being passed to the database has select permissions on this new table.
Hope this helps…
Kent Johnson
johnsonka@wellmark.com
Hi all I'm having a very weird problem, when I try to insert a new table in my universe, BO shows me the table list, but when I try to check the fields inside each table, It doensn't show me anything. I can't insert the tables either, but if I try it, it shows me the values. What can be wrong? I'm working with BO 4.3.1, Informix Dynamic Server 7.3. TIA Brgds Omar
