BusinessObjects Board
BIWS not refreshing after initial load
I have a dashboard running on 4.1. The webi report is scheduled to run every 5 minutes and have dedicated BIWS blocks for each part on the dashboard. On the dashboard for my Data Deffinition I am using GetFromLatestDocumentInstance set to 1 and usage set to Refresh Before Components Are Loaded and Refresh every 5 minutes.Initial loading of the Dashboard does load the latest instance, but it is not refreshing beyond that. Where is the breakdown?
— RESOLVED - New issue requires SP05 Patch 4
fknaut :us: (BOB member since 2005-08-04)
Are you positive that the connection is refreshing? The simplest test is to use the Loading/Idle indicators.
My guess is that the instance is being cached. Exactly where, or how you flush the cache, I don’t know. But the designers probably assumed that the latest instance generally wouldn’t be changing every 5 minutes.
