biometric data
hi, does anyone know about a software that handles biometric data and can be linked to Business Objects in order to handle this data from BO?
sabine8 :lebanon: (BOB member since 2007-01-05)
You just need software that stores its data in database which BusinessObjects can access. So provided you can find one that uses DB2, Sybase, SQL Server, Oracle etc you should be okay. Security will be an interesting issue with biometric data.
this is obvious but do u have any idea if i could display biometric data in BO (WI reports or performance manager…)
I mean can i create objects in the universe that can be used later in order to display the biometric data (like fingerprints) in the reports?
thanks again
You haven’t said what version of BusinessObjects. Here are a couple of threads about BLOBs/CLOBs.
