BI40 Users and Groups Lists
Can anyone help me to resolve this issue.
Appreciate your help.
Warm Regards
Amar
amarnatha :india: (BOB member since 2006-05-08)
very useful sharing. thanks.
I have one question.
Can we list which reports BO users have access to
Version BO4.2
gezgincomrade (BOB member since 2019-07-14)
this tool ran successfully on 32 bit version of office 365.
Amar
Has anyone figured out how to update this file for 64-bit using 4.2 SP5? This is my favorite file… :frowning:
giggles7840 (BOB member since 2007-07-13)
have run this Excel file list for years and suddenly it no longer works on any of my available desktop or notebook systems :frowning: Compile error: Can’t find project or library
Dim SessionManager, Sess As SessionMgr
Any ideas?
drankust :us: (BOB member since 2007-03-15)
Try this:
SuKA (BOB member since 2018-10-20)
Thanks that is what I already have (after looking at my post and realizing I entered the sample incorrectly) - still looking for a solution.
Hi Julien,
I have saved the Excel into Macro version (.xlsm) and also enbaled Macro in Trust Center. But file gives below below error :frowning: FYI, we are using Office 365.
sadly, there is no option to see/edit Macro or Libraries :frowning:
Thanks Julien.
Is that the latest version BOBI4_UserList_V001.zip? If yes then I will give it a try.
FYI, our verions is: BI 4.2 SP6 and Office 365
Is the latest file compatible with above verions?
Thanks for you help.
@under18 🤷
Honestly I don’t know, I have not created this particular file :innocent: I am just the creator of the original XI3 version back in the days!
I suggest to rely more on the actual version of the same tool :wink: :
https://bobj-board.org/t/bobj-bi4-2-user-list-and-group-extraction-via-spa/256347/28
