BI Workspace html code limitation
I am facing an issue while adding the html code inside a single text module in the BI workspace.
Explanation in details :
The workspace is having 2 tabs under it. Both tabs are having single text module. One tab I am able to see the contents coming up (html code is used which is 515 lines of code) but in second tab when I add html code and save the report, the content inside the 2nd tab is not visible.
I noticed it happens after adding approximately 580+ lines of html code inside a single text module.
Is there any html code line limitation for a text module which is causing this issue?
Ayushi (BOB member since 2016-09-06)
