I have a publication that sends the 1st report of a document to Email as mHTML. The 4th column in the source document is sorted descending. When the publication executes, the report shows up in email sorted by the 1st column, yet the correct source document is being used. If I refresh the source, it sorts correctly. I tried removing all sorts, then used Advanced…/Manage Sorts to add all the columns in the correct sequence to no avail. It still sorts by the 1st column.
If I send the report to Inbox, it appears correctly sorted.
Has anyone seen this, or know why it happens? Could it be a side effect of embedding the doc in Email as mHTML?
Edit: I rebuilt the report from scratch, and that fixed it.
charlie
(BOB member since 2002-08-20)
