Hi everybody,
I try to execute an sdk java program that I migrated from XI3 to BI4.2 SP3
but it does not run correctly.
the program schedule webi reports with prompts that are indicated in an xml properties file.
the schedule run correctly but when a document contains prompts with multi values, the setPrompts() function does not insert the values of the prompts.
if someone has already incounter this problem, please give me an idea to correct my code.
this is a snippet :
import com.businessobjects.rebean.wi.*;
import com.businessobjects.sdk.plugin.desktop.webi.IWebi;
import com.crystaldecisions.sdk.exception.SDKException;
import com.crystaldecisions.sdk.framework.IEnterpriseSession;
import com.crystaldecisions.sdk.occa.infostore.IInfoObject;
import com.crystaldecisions.sdk.occa.infostore.IInfoObjects;
import com.crystaldecisions.sdk.occa.infostore.IInfoStore;
import com.crystaldecisions.sdk.occa.infostore.ISchedulingInfo;
import com.crystaldecisions.sdk.plugin.desktop.program.IProgramBase;
System.out.println("================= INITIALISATION =================");
System.out.println((new StringBuilder("=== “)).append(path).append(NomDoc[0]).toString());
for (int i = 0; i < NomDoc.length; i++) {
final IInfoObjects objs = oInfoStore.query((new StringBuilder(“Select * From CI_INFOOBJECTS Where SI_KIND in (‘Webi’,‘FullClient’) And SI_INSTANCE=0 And SI_NAME = '”))
.append(NomDoc[i].replaceAll(”’", “’’”)).append("’ and SI_PARENT_CUID =’").append(last_id).append("’").toString());
System.out.println((new StringBuilder(“Select * From CI_INFOOBJECTS Where SI_KIND in (‘Webi’,‘FullClient’) And SI_INSTANCE=0 And SI_NAME = '”))
.append(NomDoc[i].replaceAll("’", “’’”)).append("’ and SI_PARENT_CUID =’").append(last_id).append("’").toString());
for (int compteur_doc = 0; compteur_doc < objs.size(); compteur_doc++) {
final IInfoObject obj = (IInfoObject) objs.get(compteur_doc);
final String chemin = GetParentArbo.getParentfolderPath(oInfoStore, obj.getCUID());
GetParentArbo.path = “”;
for (int a = 0; a < bloc.length; a++) {
System.out.println("");
System.out.println("================= TRAITEMENT =================");
bloc[a] = bloc[a].replace("@rmaeq", rmaeq).replace("@rmaem", Date.getLastMonthLastDate(“dd/MM/yyyy”)).replace("@DernierJourOuvreDuMois", DernierJourOuvreDuMois)
.replace("@num_mois_prec", num_mois_prec).replace("@num_annee_prec", num_annee_prec).replace("@num_annee", num_annee).replace("@end_month(2)", end_month2)
.replace("@begin_month(2)", begin_month2);
System.out.println((new StringBuilder(“Planification avec les valeurs '”)).append(bloc[a]).append("’").toString());
//p_parameters = bloc[a].split("\244");
p_parameters = bloc[a].split(";");
final IWebi webi = (IWebi) objs.get(compteur_doc);
final DocumentInstance documentInstance = reportEngine.openDocument(webi.getID());
documentInstance.refresh();
/*try{
documentInstance.getDataProviders().runQueries();
}catch(Exception e){
System.out.println(e);
final Prompts prompts = documentInstance.getPrompts();
System.out.println((new StringBuilder("Nombre d'invites : ")).append(prompts.getCount()).toString());
if (p_parameters[0].equals("")) {
titre = INSTANCE_TITLE;
} else if (prompts.getCount() != p_parameters.length) {
throw new Exception("le nombre d'invites ne correspond pas avec celui attendu");
System.out.println("----PROCESSING----");
for (int j = 0; j < prompts.getCount(); j++) {
final Prompt prompt = prompts.getItem(j);
final String p_parameter = p_parameters[j].trim();
if(!p_parameter.equals("")){
if (prompt.getType() == PromptType.Mono) {
if(prompt.hasLOV() ){
String curPromptVal = p_parameters[j];
ValueFromLov[] set = new ValueFromLov[1];
Lov lov = prompt.getLOV();
Values vals=lov.getAllValues();
set[0]=null;
for(int lovI=0;lovI<vals.getCount();lovI++){
if(vals.getValue(lovI).equals(curPromptVal)){
set[0] = vals.getValueFromLov(lovI);break;
System.out.println("Mono - Inside prompt has LOV >> set >> "+p_parameter);
titre = titre.replace(prompt.getName(), p_parameter);
if(!(set.equals(null) & prompt.isOptional()))
prompt.enterValues(p_parameter.split(","));
else
prompt.enterValues(set);
}else{
final String vals[] = new String[1];
vals[0] = p_parameters[j];
System.out.println("Mono - no Lov >> set >> "+vals[0]);
titre = titre.replace(prompt.getName(), vals[0]);
prompt.enterValues(vals);
} else {
String[] curPromptVals = p_parameter.split(",");
ValueFromLov[] set = new ValueFromLov[curPromptVals.length];
int index=0;
for (String curPromptVal : curPromptVals){
set[index] = vals.getValueFromLov(lovI);
break;
index++;
System.out.println("Multi - Inside prompt has LOV >> set >> "+set[index-1].getValue().toString());
titre = titre.replace(prompt.getName(), set[index-1].getValue().toString());
}else{
int iPosBegin = 0;
int iPosEnd = 0;
int iNbValue = 0;
final String lsParam = p_parameters[j];
while (iPosEnd != -1) {
iPosEnd = lsParam.indexOf(";", iPosBegin);
iPosBegin = iPosEnd + 1;
iNbValue++;
final String vals[] = new String[iNbValue];
iPosBegin = 0;
iPosEnd = 0;
iNbValue = 0;
final Calendar cal = Calendar.getInstance();
final int month = cal.get(2) + 1;
iNbValue++;
if (iPosEnd == -1) {
vals[iNbValue - 1] = lsParam.substring(iPosBegin, lsParam.length());
} else {
vals[iNbValue - 1] = lsParam.substring(iPosBegin, iPosEnd);
titre = titre.replace(prompt.getName(), vals[iNbValue - 1]);
if (!(prompt.isOptional() & vals[iNbValue - 1].replace(" ", "").equals(""))) {
System.out.println("Multi - no Lov >> set >> "+vals[0]);
//PromptsUtil.populateWebiPrompts(prompts, webi);
//try{
// documentInstance.getDataProviders().runQueries();
//catch(Exception e){System.out.println(e);};
documentInstance.setPrompts();
documentInstance.save();
System.out.println("----AFTER SETPROMPTS----");
for (int j=0; j<prompts.getCount();j++){
if(prompt.getCurrentValues().length>0){
System.out.println("Mono -> CurrentValues de "+prompt.getName()+" "+prompt.getCurrentValues()[0].toString());
if(prompt.getPreviousValues().length>0){
System.out.println("Mono -> PreviousValues de "+prompt.getName()+" "+prompt.getPreviousValues()[0].toString());
if(prompt.getDefaultValues().length>0){
System.out.println("Mono -> DefaultValues de "+prompt.getName()+" "+prompt.getDefaultValues()[0].toString());
}else{
System.out.println("Multi -> CurrentValues de "+prompt.getName()+" "+prompt.getCurrentValues()[0].toString());
System.out.println("Multi -> PreviousValues de "+prompt.getName()+" "+prompt.getPreviousValues()[0].toString());
System.out.println("Multi -> DefaultValues de "+prompt.getName()+" "+prompt.getDefaultValues()[0].toString());
THANKS A LOT
mamentague (BOB member since 2017-05-16)
(BOB member since 2007-04-16)
