Best distribution method?
I have 3 clients, each client has there own physical installation. however, I want o be able to work on a local installation and migrate universe, reports, etc…
Due to the CUID process, how can I accomplish this without breaking each clients personal reports to universes.
e.g.
Universes saved as “Planes”, “Boats”,“Cars”, 6 months later , I want to be able to povide a universe update and migrate my locale universes with the updates to each client, but this will break all of their personal reports.
MichaelB :us: (BOB member since 2008-11-19)
You didn’t mention what version you are using so I’ll assume XI 3.x. Use the Import Wizard to export your universe to a BIAR file which will keep the CUID intact. If the universes located at each of your clients contain different CUIDs than those of your local copy, I would do a 1-time import from your clients to your PC again using the IW. This way you know the CUIDs will match in the future.
BoB LoblaW :us: (BOB member since 2007-10-23)
